hello
I have a question about automix,,,, not real DJ's vs Jukeboxes
I use automix sometimes during cocktail parties, and for playing back ground music.
so my question : is there a setting to keep automix from starting the next song ,if you double click to load the song.
example
if in automix mode and I double click to load a song from the browser or the side list ,the song loads in the non playing deck and waits till its time to be played.
if in automix mode and I double click on a song to load from the automix list VDJ fades to the newly loaded song and starts playing the song.
i am using ver 8.3
is there a way to change this setting
Thanks
Al
example
i am using ver 8.3
Thanks
Al
geposted Sun 27 Oct 19 @ 2:50 am
Surely that's expected behaviour? There's a right click menu for 'play next'.
geposted Sun 27 Oct 19 @ 9:14 am
That is the expected behavior. If automix is on, double clicking will mix now. If it’s off it will load to the inactive deck.
There is no setting to change this
geposted Fri 01 Nov 19 @ 9:29 am
Thanks
geposted Thu 02 Apr 20 @ 10:56 pm
