Topic: Sliding Effect Gui Panel?
RanikiPRO InfinityMember since 2018
Is there any way of making the panel that pops up if an Effect Gui is selected slide in and out of view like the 'SideView' Panel or the 'File Info' panel.
I find it really useful to have the more detailed information for some effects available, however if they are permanently visible it takes up quite a lot of Interface Real Estate. So to have a sliding panel with this information that could be made visible or not depending on need would be really useful.
Alternatively is there any way that a sideview panel can be used for this information?
Thanks for any help
geposted Mon 28 Oct 19 @ 10:13 am
show_pluginpage
geposted Mon 28 Oct 19 @ 10:18 am
Wow - that was fast!
Just tested that and it works :-)
You're a star Locodog.....
geposted Mon 28 Oct 19 @ 10:25 am
BTW while we're here - what is the difference between:
show_pluginpage
and
show_splitpanel
I've never quite worked out the difference between the pluginpage, a panel, a split panel and a panel group.....
geposted Mon 28 Oct 19 @ 10:44 am
