I've just purchased a Hercules P32 which is supported by current version of VDJ but not in VDJ 7.
I've had some trouble with version 8 during live gigs and have decided to stay with version 7 since then.
I'm ready to give more tries to the current version but would want to keep version 7 as a back up for the peace of mind.
Is there any way to export or download controller definition file of P32 that is embedded in the current VDJ so I can modify and remap it to be used in VDJ 7 as well?
I'm currently in the process of making both definition and mapping file from scratch but it'll be so much helpful if I can have the current definition file as a reference.
Thanks.
Thanks.
geposted Wed 27 Nov 19 @ 7:20 pm
No, not possible.
geposted Wed 27 Nov 19 @ 7:22 pm
