See below:
geposted Thu 28 Nov 19 @ 9:45 pm
There seems to be a potential bug on the main skin with regards to pad button colours.
If you load a pad page which has assigned colours and then load a different pad page which has pad buttons that aren't currently assigned, the colours from the previous pad page transfer over.
It's a bit complicated to explain so here's an example with an image:
1 - VDJ Loads up with no track loaded on the deck - All pad buttons are greyed out as expected
2 - I load a track with 2 hot cues (both generic colour)
3 - I change the pad page to Saved Loops - this track has no loops but the 2 hot cue colours have transferred over (when they should be greyed out)
4 - I switch to Beat Jump and all the beat jump colours are as normal (as Beat Jump utilizes all the pad buttons)
5 - I switch back to Hot Cues and the empty Hot Cues are now coloured as the Beat Jump buttons (no longer greyed out)
geposted Thu 28 Nov 19 @ 9:46 pm
Set the setting experimentalSkinEngine to No from VirtualDJ Settings->OPTIONS tab
geposted Fri 29 Nov 19 @ 1:42 pm
