Hi all, recently had my pc upgraded to W10 and in the meantime vdj2020 has been released.
VDJ 8 worked fine on W7 on the same machine, also works fine on W10.
If I try and open 2020 it says there's a directx issue.
There is no graphics card, just an Intel g33/31 chipset, with an Intel quad core 2.8ghz and 4gb ram.
So I'm thinking my graphics card is incompatible with directx 12? Is this the version vdj2020 uses or is it possibly another reason?
As a slight aside one of my youngsters wants to start using the PC for Fortnite, it's a budget set-up so if I were to invest in a graphics card such as a Nvidia GTX660 would this kill two birds with one stone?
geposted Fri 29 Nov 19 @ 12:02 pm
direct x11
geposted Fri 29 Nov 19 @ 1:01 pm
You should still be able to use the 32bit version of VirtualDJ
Download Page
![](/img/301359/96691/32bits.png)
geposted Fri 29 Nov 19 @ 1:45 pm
Thanks, will try.
geposted Fri 29 Nov 19 @ 5:43 pm
