When I go to audio settings, under inputs, I have my pioneer ddjsx2 Wasapi connected on chan 1 and 2, but it days error at the end. When I mouseover the ddjsx2 in that area, it says not connected: getmixformat failed. What gives?
Thanks!
Thanks!
geposted Fri 29 Nov 19 @ 11:04 pm
Why are you using WASAPI? The SX2 has its own ASIO driver. You should be using that for best results.
geposted Sat 30 Nov 19 @ 7:28 am
I dont have the asio option. I guess I'm missing a driver?
geposted Fri 06 Dec 19 @ 11:31 pm
For most of the Pioneer hardware, i'd say the ASIO driver is important to install and use.
https://www.pioneerdj.com/en/support/software/archive/ddj-sx2/#drivers
Setup http://www.virtualdj.com/manuals/hardware/pioneer/ddjsx2/installation.html
Also check this out .. http://www.virtualdj.com/manuals/hardware/pioneer/ddjsx2/advanced.html
Note that in case you want to use Timecodes, there is no spare input to use for recording.
geposted Sat 07 Dec 19 @ 7:01 am
