Can all effects be applied to the sampler? If not...which ones are and are not?
geposted Mon 16 Dec 19 @ 4:06 am
Some can't be chosen, some can be chosen but won't work.
geposted Mon 16 Dec 19 @ 4:34 am
Was particularly interested in applying the cut/transform effect..
geposted Mon 16 Dec 19 @ 4:42 am
try it...
geposted Mon 16 Dec 19 @ 5:05 am
The Cut effect works fine with the new sampler effect slot (still only in EA releases, I think)
But remember that samples that is for instance someone saying/shouting something often got bpms and grids that are way off because there is no beat to detect
So effects that rely heavily on the beat/bpm like cut may sound a little... funky
You can of course correct the BPM and grid in the sample editor - if bpm on some talking even make sense
geposted Mon 16 Dec 19 @ 9:35 am
