Hi, I just bought an entry level Numark Mixtrack Pro II, these have been about for sometime so I thought the Mixtrack II skin provided would be mapped correctly but i cant get my hotcues to play when i press any of the pads, they just use the loop in/out and select the effects?
How can i change this; even if it means remapping the LOOP IN/OUT/RELOOP/LOOPSIZE or the HOT CUE 1,2,3 and 4 or FX1,2,3 and TAP functions?
Would it be possible to programme it so that the hotcues were there then maybes press the shift key on the controller to access the FX or Loops?
geposted Mon 23 Dec 19 @ 8:10 am
How can i change this; even if it means remapping the LOOP IN/OUT/RELOOP/LOOPSIZE or FX1,2,3 and TAP functions?
geposted Mon 23 Dec 19 @ 9:58 am
go through these pages of the manual and you will see how the default mapping is setup.
https://virtualdj.com/manuals/hardware/numark/mixtrackpro2/controls.html
skin has nothing to do with mapping also there is no rule the skin needs to match the controller you would probably be better off using one of the default skins.
geposted Mon 23 Dec 19 @ 11:17 am
When i use the default skin it says the hotcues are assigned to the pad that why i tried the skin in the first place i would rather use the defualt:
geposted Mon 23 Dec 19 @ 11:22 am
thanks the article helped!
geposted Mon 23 Dec 19 @ 11:24 am
