Love this plug in. Really miss it. Any news or Beta available?
geposted Tue 31 Dec 19 @ 9:43 pm
WinAmp still works on Win 10 as does Milkdrop.
If you configure WinAmp to use system sound as the input, Milkdrop then responds to VDJ.
Here's a video I made yesterday with Milkdrop and VDJ:
https://www.bitchute.com/video/f6hy1uPeu2py/
geposted Thu 02 Jan 20 @ 11:20 am
Looks very nice. Yet I'm a little confused. I would need to load Winamp and play Milkdrop video through it, I get that. But does VDJ use Winamp as a Plug-in?
I would want Milkdrop playing through VDJ like it used to work. Dang it... I should have stayed 32 bit until these little annoyances are fixed.
geposted Thu 02 Jan 20 @ 10:33 pm
1. Install WinAmp
2. Enable "line in" as a source
3. Turn on Milkdrop by hitting the play button WinAmp
4. Enable screen capture via VDJ and set the size of the screen capture window to match Milkdrop's window
5. Start some music: voila. Milkdrop in VDJ.
This is a bit simplified. There are a ton of Milkdrop settings to customize it for your computer and display.
geposted Fri 03 Jan 20 @ 3:09 pm
geposted Fri 03 Jan 20 @ 5:05 pm
