Trying to map one of the sliders on my class compliant controller (Panda 200) to browser_scroll. In the definition I have set minimum, maximum, full rotation, and zero point (middle):
<slider name="BANK1 KNOB1" cc="0x009" min="0x000" zero="40" max="0x07f" full="24" channel="9"/>
with or without any of these parameters in the definition the result is the same: move the slider up or down and it scrolls down. When it reaches the last song it stops responding.
(it's actually a knob but VDJ sees it as a slider. and any of my sliders have the same minimum, maximum and the same problem)
I found an older closed thread but it was in V7, and he was using an infinite encoder knob. Mine is not infinite, and the guy didn't post a resolution to the problem.
mapper:
<map value="BANK1 KNOB1" action="browser_scroll" />
How do i scroll both ways?
mapper:
geposted Thu 02 Jan 20 @ 3:28 am
Right out of the Wiki. Just had to try different ones till i got the result:
<fullencoder cc="0x009" name="BANK1 KNOB1" mask="0x1F" full="20" zero="0x19" channel="9"/>
It is still a little too sensitive for my taste but will do for now. Scrolls up and down
geposted Thu 02 Jan 20 @ 5:17 am
