Topic: Pioneer DDJ-800 / Mono signal in booth output update?
Just wondering if Atomix still plans on implementing the mono signal in the booth output?
geposted Mon 06 Jan 20 @ 8:15 am
((( tumbleweeds )))
geposted Fri 10 Jan 20 @ 10:00 pm
doesn't this script do it?
mono_mix
geposted Fri 10 Jan 20 @ 10:02 pm
That'll do it - but for all outputs (including the master).
It would be preferable if it were able to be assigned, so mono_mix booth or mono_mix master.
I for one use a single speaker if I need a booth monitor, so being able to make that o/p mono without affecting the master would be best.
geposted Fri 10 Jan 20 @ 11:54 pm
Ah yeah, I get you, I run mono all the time.
does this do it?
geposted Sat 11 Jan 20 @ 12:31 am
EXACTLY!!! I couldn't have said it better.
geposted Thu 16 Jan 20 @ 2:42 am
mono_mix
That did the trick for me. THANKS!!!
geposted Thu 16 Jan 20 @ 2:44 am
You all really have so much music where not hearing one side would make any significant difference?
geposted Thu 16 Jan 20 @ 7:55 am
Yep.
geposted Sat 18 Jan 20 @ 10:30 am
