Hey, I bought the full "VirtualDJ Controller License" to use with my Pioneer WEGO 3 controller few years back. Now I will be getting myself a new controller from Numark. I was wondering whether I can still use the same license that I got earlier or do I have to buy myself a new one? The fellow I'm buying the controller from is using VDJ too so the controller is supported. Biggest difference would probably be 2 decks vs 4 decks. Thank you!
geposted Sat 11 Jan 20 @ 3:30 pm
Firstly, a controller license (or Plus license) is not a "full" license.
Secondly, the Plus licenses are locked to the named controller (that's why they're cheaper than the full license), so no you cannot use your license with another controller. You will have to buy another license. You should buy the full Pro Infinity license if you want to avoid paying again when you change controllers.
geposted Sat 11 Jan 20 @ 3:57 pm
