Topic: VDJ 2020 - karaoke playback issue
I downloaded the vdj 2020 and get free trial period ....
When I go to play karaoke with the mp3 and cdg files unzipped it won’t display lyrics , but with both files zipped together works perfect is it something I have in my settings incorrectly or is it that I will need to zip all my unzipped files back together (this will take forever)
tia
geposted Sun 12 Jan 20 @ 8:57 am
Thanks for the reply
They are all named correctly and used to work on vdj le fine
And if I zip the files together they then also play fine
Just going to be a long task redoing the tracks
