Hi everyone! im testing the new version, x64 to be specific.
Playing audio looks good, i have been mixing for a half hour and everything goes normal... the problem is when you charge some videos.
In my case, while playing videos on deck A and B and open a new window (any window in software... configuration, shader personalization, bpm editor, etc.) the program crashes 2 times...
In the first crash, it tries to continue but inmediatly hangs again and makes a ''clean open'' (everything its reseted)
Any solutions? Anyone else its suffering this?
Version 8.4-64 b5478
Windows 10 Home
i5 7300hq
16gb RAM
GTX 1050 mobile
Corsair MP510
Windows 10 Home
i5 7300hq
16gb RAM
GTX 1050 mobile
Corsair MP510
geposted Sun 26 Jan 20 @ 6:45 pm
It looks like your crash is related to RTSSHooks64.dll, which seems to be RivaTuner. So try to either see if there's an update for this software, or try if uninstalling it fixes the problem.
geposted Sun 26 Jan 20 @ 7:18 pm
Ok! i will try and comments results! Thank you!
Edit: It worked! I did not have to uninstall, just close MSI Afterburner (and therefore RivaTuner) from the taskbar and apparently it does not fail anymore.
I will continue testing everything, thank you very much for your help and I hope they are compatible in some next update!
Regards!
Regards!
geposted Tue 28 Jan 20 @ 2:43 am
