Once again , im trying to do something i totally haven't done in years , i have my head kinda wrapped around it. But could use some help. How would i go in midi ox to change the midi channel of two same devices so that i can map them separately in virtual dj? for example APC 40 and APC 40 . I want one to do video and one to do audio ad-dons. Advice an help would be great . Respect to all the people doing all the help here and upgrades on the software.
geposted Tue 28 Jan 20 @ 8:02 pm
Unless you are connecting devices using actual MIDI cables and not USB, you don't need to change anything, and VirtualDJ will see each device separately, and you can map them independently.
geposted Tue 28 Jan 20 @ 8:16 pm
i tried to use it and the second unit responds to the mapping of the first one . P,s thanks for your help
geposted Tue 28 Jan 20 @ 8:38 pm
You have separate mappings?
geposted Tue 28 Jan 20 @ 8:46 pm
i got it figured out . What happened was the order that i turned the units on effected the sequence. i had to go into the mapping and remap the second set of buttons , i now have 160 buttons .. thank you all for the help, Its going to be awesome
geposted Tue 28 Jan 20 @ 8:50 pm
