Hi to all
Please can anyone advise the following :-
1. When you load a track and play it and then adjust the EQ settings are you able to save the EQ settings ( for the track you are playing only ), so when you next play the newly EQd track it plays from how you saved it or will it reset back to default ?
geposted Wed 29 Jan 20 @ 10:34 am
It will reset, if you really want a track to have altered eq then, rerecord it with an altered eq.
geposted Wed 29 Jan 20 @ 11:01 am
thanks for the reply , I think i will use Audacity for the eq and save the file then import in to VDJ
geposted Wed 29 Jan 20 @ 2:15 pm
