I'd like to be able to temporarily set the booth_volume to off (0%) and the headphone_volume to 20%, and then set them back to the same volume they were previously.
If I manually set the BOOTH_VOLUME knob to something like 20%, and write a script like:
down ? booth_volume 0% : booth_volume 50%
the volume will jump up to 50% after I let up on the key instead of the 20% I had previously manually set.
it seems that with deck volume I can use get_volume to set the volume to a variable for later use, ala ...
set "$deck1-volume" '`deck 1 get_volume & param_cast float`' & ...
The docs at https://www.virtualdj.com/wiki/VDJscript_verbs_v8.html also seem to suggest that there may be a "get_level 'mic'" and "get_level 'sampler'". Are "headphone" and "booth" considered "decks" such that I could set a variable to "get_level 'booth'" or "get_level 'headphone'" and use it to reset the volume later?
geposted Thu 30 Jan 20 @ 2:05 am
1- why not to simply use the dedicated while_pressed verb ?
booth_volume 0% while_pressed
headphone_volume 20% while_pressed
https://www.virtualdj.com/wiki/vdjscript.html
The full command syntax is:
[deck [deck]] verb [param1] [param2] [while_pressed]
the undocumented "temporary" and "momentarily" and "smart_pressed" are also possible
2- no these are not "all" decks, but yes you can use headphone_volume and booth_volume and sampler_volume and sampler_volume_master and mic_volume and mic2_volume ... as a query to set a variable - not global one in these examples:
deck 1 set "deck1-volume" `booth_volume ` & ...
to restore :
... get_var "deck1-volume" & booth_volume
to restore :
geposted Thu 30 Jan 20 @ 3:39 am
Cool. Once again I was making this way more difficult than it needed to be.
Many Thanks.
Many Thanks.
geposted Thu 30 Jan 20 @ 3:01 pm
