Can you edit Ratings from within the browser or Sidelist / Automix or from a deck?
I can move my mouse to the song, right-click it, move my mouse up to tag editor, move my mouse to enter a rating, click ok. Much simpler in MediaMonkey, iTunes, etc etc. Is there a simpler way?
I searched Deezer for "Valentines" and of course rejected most songs. How can I not listen to those same songs if I search again next year? My answer is to rate them. Is there a better way? Will VDJ remember my rating for an online song a year later? If I add the new year, will all songs added to deezer (or soundcloud or wherever) in the last year appear, or only songs with that year in the name of the song or album? I found a ton with 2020 in the album title - many/most of which are not new to 2020!
For downloaded music, I keep crap on my laptop so it shows up in my database so I don't download something again because it has a good title (and I forgot I listened to it a year before). Is there a better way?
geposted Sun 02 Feb 20 @ 4:17 pm
geposted Sun 02 Feb 20 @ 4:23 pm
Thanks!
Do you happen to know if VDJ will remember my rating for an online song I only played once a year later? (Played for myself, not as a DJ'd event.)
Do you happen to know if VDJ will remember my rating for a downloaded song if I delete the song?
geposted Sun 02 Feb 20 @ 4:50 pm
I don't, give it a try and report your findings.
geposted Sun 02 Feb 20 @ 5:24 pm
You can also map some buttons or keys on your keyboard.
rating 1
rating 2
rating 3 ....
and if the song is loaded on the deck just press you button.
rating 1
rating 2
rating 3 ....
geposted Wed 05 Feb 20 @ 8:26 am
@Pachn,
cool thanks.
cool thanks.
geposted Thu 06 Feb 20 @ 8:44 pm
