When reading tags the tag editor reads my .mp3 files fine. However .flac files the tag editor does not read the year and comment fields. I downloaded the same file from the same program and .mp3 read fine. .flac files are missing year and comment field information. If I was doing just a few files this is not a problem. I am doing over 6,000 files and have to fill in the fields every time. Is there a solution to this or should I just grin and bear it?
geposted Thu 06 Feb 20 @ 2:23 am
Are you sure the flac files contain the year in the tag then? Virtualdj can read flac tags so it should work
geposted Thu 06 Feb 20 @ 3:14 am
I download the song. I fill in the information in the windows file explorer, Title, Comments, Contributing Artist, Date & Genre. When I import it into VDJ the year and comment fields are blank.
geposted Thu 06 Feb 20 @ 1:34 pm
FLAC uses Description field instead of comment in VDJ
but year is the same
geposted Fri 07 Feb 20 @ 2:03 am
On the tag editor screen the flac tags available are underneath the boxes. Click the little circle with the up arrow and it will import the tag. There is a comment tag but no year.
geposted Fri 07 Feb 20 @ 2:20 am
Will fix. It looks like Windows Explorer uses a non-standard way to store the comments and year (using YEAR and DESCRIPTION fields instead of DATE and COMMENT fields)
geposted Fri 07 Feb 20 @ 9:17 am
Thanks Adion for your help.
geposted Fri 07 Feb 20 @ 3:34 pm
