is it possible to map the color fx selector to a rotary knob so as to quickly cycle through the different color fx's? i do not use the gain knob on my controller as if i have to do gain adjustments(i barely do),i do them directly on the skin. i have found that in mixes..i only can decide the color fx that i want to be applied at the last seconds and this request may make things a bit easier..
ps. i am not asking about applying the effect itself..i already have the filter rotary knob mapped for that.
geposted Tue 11 Feb 20 @ 11:15 pm
i have found it...mapping the gain knob to "filter_selectcolorfx" works perfectly.
geposted Wed 12 Feb 20 @ 12:57 am
figured you'd get it once you went looking.
geposted Wed 12 Feb 20 @ 1:45 am
Yah...i did!
geposted Wed 12 Feb 20 @ 3:15 am
