when I upload track y is it at times it loud or quiet I had this problem in the old version was able to fix it in settings can you help
geposted Thu 13 Feb 20 @ 1:47 pm
Im have a problem with volume when up loading a track sometimes the volume is blasting or to low how do i fix it to keep it even
geposted Thu 01 Jul 21 @ 11:42 pm
Before song is fully analyzed (for volume and gain) ?
Or songs you have previously played? If so, perhaps you have set autogain to "auto+remember".
Set it back to just auto (in VirtualDJ option settings)
geposted Fri 02 Jul 21 @ 11:51 am
Mp3gain your whole collection.
I also use BreakawayDJ during the set. Everything nice and leveled.
geposted Sat 03 Jul 21 @ 11:04 am
Note that if only using vdj you don't need mp3gain, and also remember that if you do want to use it make sure you rescan your library after.
https://virtualdj.com/wiki/VDJ8%20Limiter.html
geposted Sat 03 Jul 21 @ 11:54 am
