geposted Sun 23 Feb 20 @ 6:29 am
it means that inside there are one or more folders
geposted Sun 23 Feb 20 @ 7:49 am
Ok but then i think i found a bug, there is no folder inside this virtual folder
geposted Sun 23 Feb 20 @ 1:33 pm
It is a bug of sorts. Go to your VDJ folders in documents then folders. You will see a subfolder for 1990,just delete it then restart VDJ
geposted Sun 23 Feb 20 @ 3:12 pm
But the i will not have any the hits of 90 in the virtual folder if i delete it, i can live with the triangle..
geposted Sun 23 Feb 20 @ 6:28 pm
No, don't delete the actual folder, there will be an entry for subfolder somewhere, I just can't remember where in the directory it is as I fixed my ones.
geposted Sun 23 Feb 20 @ 6:49 pm
Ok i will try that.
geposted Sun 23 Feb 20 @ 7:27 pm
