Hello, I'm trying to broadcast my DJ mixing using the "Audio" only option in Broadcast. I press "Start Broadcast", it says broadcasting. I send out my link. People click on the link. It says "Broadcasting", but no body can hear anything. Just silence.
I've gone into my settings and made sure that port 8000 is open in the firewall. I also rand the little port checking utility. It shows that port 8000 is open. Is there something else I need to check? I cannot get this to work.
geposted Wed 26 Feb 20 @ 4:23 pm
....and what are your audio settings? What hardware (controller etc) are you using, if any?
geposted Wed 26 Feb 20 @ 5:28 pm
I'm using an American Audio VMS2. Default settings for the audio controller. No issues playing music live. Just not able to broadcast. Is there something I should change or set?
geposted Wed 26 Feb 20 @ 9:15 pm
OK I can see from the VDJ setup guide for the VMS2 that it uses an external mixer config.
The broadcast option in VDJ expects to get audio from the internal software mixer, so if you're not using the software mixer, you need to read the following wiki page:
https://www.virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html
geposted Wed 26 Feb 20 @ 10:26 pm
Awesome. Thank you for that link. I had no idea and for some reason never saw that. Thank you. I really appreciate your help. I'll check into it. Again, many thanks!
geposted Thu 27 Feb 20 @ 5:42 pm
