hi
I using the relocate missing files search I created a Filter exists=0 and then highlight all and hold the enter key down since there is not batch program nore does it skip ones it cant find
but im finding its Writing Tags and I don't want to write Tags from the Filename how you stop it.. I looked in settings searched for TAGs but nothing that disables tag writing when relocating files
geposted Thu 27 Feb 20 @ 5:07 am
Disable setTagsAuto
geposted Thu 27 Feb 20 @ 5:46 am
