it seems you can with RB. i have the vdj timcodes. could it work?
geposted Tue 17 Mar 20 @ 10:25 am
Should be able to, it has line-ins that can be set to timecode inputs
(change line in entries in image below to timecode)
![](https://www.virtualdj.com/img/292595/56124/Sound%20Setup%20Default.png)
geposted Tue 17 Mar 20 @ 11:13 am
thank u
geposted Wed 18 Mar 20 @ 9:10 am
I have a problem ... when I make a custom audio setting and then save, when I restart the program I don't start with the saved configuration but I start with the default configuration
geposted Wed 08 Apr 20 @ 4:34 pm
MAC or Windows ?
Make sure VirtualDJ has sufficient privileges to write files on Documents\VirtualDJ folder
geposted Wed 08 Apr 20 @ 5:59 pm
