hello legends :)
is it possible to mix tracks with a friend online?
I'm in a different state to my friend.
If possible - do we both need the same MP3 files?
Kindest regards :)
Kindest regards :)
geposted Tue 24 Mar 20 @ 10:08 am
But you are not at same computer, so that would not be easy.. or "possible" ;-)
You can always use some desktop sharing tool, so he can access your computer desktop remotely, and you can do it together..
At least as a "tutorial/teach" approach that might be ok (Teamviewer.com etc are free)
Or you can take turns perhaps, do a Skype call, and mix one at a time for a bit - each at their own computer ;-)
geposted Tue 24 Mar 20 @ 1:32 pm
If you meant mix FOR a friend, for him to listen to, then VirtualDJ have several built-in broadcast options..
All from Youtube & Facebook, to personal direct broadcast or radio
See here: https://virtualdj.com/manuals/virtualdj/settings/broadcast.html
and https://virtualdj.com/wiki/videobroadcast.html
geposted Tue 24 Mar 20 @ 1:34 pm
Thinking of something like that but never took time to test
May be interesting to try,
2 local decks and 2 distant decks using VBAN
(Would need both a registered Voicemeeter and VDJ pro)
using its remote midi facility maybe would be possible to map a sort of cross controller
First DJ :
deck 1 -> stream 1 -> VBAN out
deck 2 -> stream 2 -> VBAN out
VBAN in -> stream 3 -> line 1 -> deck 3
VBAN in -> stream 4 -> line 2 -> deck 4
main ==> Master output device
Second DJ :
deck 1 -> stream 3 -> VBAN out
deck 2 -> stream 4 -> VBAN out
VBAN in ->stream 1 -> line 1 -> Deck 3
VBAN in -> stream 2 -> line 2 -> deck 4
For tests
First DJ :
main -> stream 1 -> VBAN out
VBAN in -> stream 2 -> line 1 -> deck 3
Second DJ :
deck 1 -> stream 2 -> VBAN out
VBAN in -> stream 1 -> line 1 -> deck 3
First DJ :
Second DJ :
For tests
First DJ :
Second DJ :
geposted Tue 24 Mar 20 @ 2:42 pm
Very interesting task
geposted Thu 26 Mar 20 @ 10:31 am
