I started 4 days the virtual dj (with connecting with shoutcast), since yesterday it work all fine, today i broadcast with vdj but my link to shoutcast give me link "The file you requested could not be found". So nobody can listen to listen to my music anymore, do anybody knows that the problem can be?
geposted Fri 27 Mar 20 @ 12:38 am
That is a file error message. I guess you mean you saw this on deck? If so, the song you tried load. does not exist anymore at the location set in the database.
(perhaps you renamed, deleted or moved outside VirtualDJ)
geposted Fri 27 Mar 20 @ 12:42 am
Sorry maybe i was not clear, if you use my url https://streamingv2.shoutcast.com/sweetiesradio , get this message, but i see on my vdj that i am broadcasting , so don't know why the url don't work?
geposted Fri 27 Mar 20 @ 12:52 am
That just means the url is wrong...
Check with the site/host what the proper url is.
At least there should be a port in there
Something along https://streamingv2.shoutcast.com:8000/sweetiesradio ...
(but doesnt seem to be port 8000, so some other port likely :) )
geposted Fri 27 Mar 20 @ 1:11 am
I use shoutcast v1, this is the link i get from them (what i use for 4 days now) streamingv2.shoutcast.com/sweetiesradio, i didn't change anything.
geposted Fri 27 Mar 20 @ 1:18 am
Pretty sure there is a port lacking in that url..
Shoutcast rarely ever runs on regular website url, but on a dedicated port as a server.
geposted Fri 27 Mar 20 @ 1:19 am
Checked, you might be right, that there is no port needed.. At Shoutcast.com/Radionomy.com as host provider
If so then your name at end is probably wrong or misspelled..
Or server is not up and running. Check on the control panel on the shoutcast host
geposted Fri 27 Mar 20 @ 1:26 am
i don't know anymore now, all the settings are correct at the vdj
protocol - shoutcast
encoding quality - 128 kbps (default)
serverurl - masterv.shoutcast.com
server port - 8000
login - source
password - ***********
so that's all oke, bcoz i see i am broadcasting on masterv.shoutcast.com, otherwise i get an error msg for not login in.
I already send msg to shoutcast what the problem maybe can be, i didn't change anything for the last 4 days (all was working fine), but today nothing, thanks for the help so far.
on shoutcast connection its say:
Server URL - m
masterv2.shoutcast.com
Port - 8000
and then my sream id and password
server port - 8000
login - source
Server URL - m
Port - 8000
geposted Fri 27 Mar 20 @ 1:45 am
sorry it was masterv2.shoutcast.com (forgot the 2)
so it has a port :)
http://masterv2.shoutcast.com:8000/sweetiesradio there :)
and Beth is an awesome song ;-) Peter rocks ...hehe
geposted Fri 27 Mar 20 @ 1:50 am
yes it works, you are my hero of today, thank you so much for this great quick response. greetings from a dutch guy living in the states :)
geposted Fri 27 Mar 20 @ 1:57 am
only the side don't give me the song etc. but that is an issue of shoutcast already answer them, but they are so slow in responding, again thanks a lot
geposted Fri 27 Mar 20 @ 1:59 am
Hopefully they will sort that for you ;-) and no problem..
geposted Fri 27 Mar 20 @ 2:01 am
