Good morning !! I did a broadcast 2 days ago for the first time and then this message comes out to me:
Ups! Failed to connect to the DJs broadcast.
This broadcast is not reachable. Either the DJs computer has no open port for incoming connections, or the DJ has already finished broadcasting.
I use MACBOOK 12inch 2015 with OS CATALINA
Do you have any idea how I can handle it?
geposted Sun 29 Mar 20 @ 12:55 pm
You probably need to open port 8000 at your computer
When you have VirtualDJ broadcast running, use this https://www.canyouseeme.org/ and enter port 8000
Can your computer be reached?
If not, then something is still blocking.
Try find your router model here https://portforward.com/router.htm to make sure you did the right thing.
As well as make sure VirtualDJ is not blocked in any software firewall, "anti virus suite" etc
geposted Sun 29 Mar 20 @ 2:02 pm
Thanks a lot
I have solved it
I have solved it
geposted Sun 29 Mar 20 @ 7:14 pm
No he podido resolver.
geposted Sat 13 Jun 20 @ 11:13 pm
