Hi, I have 2 old iPads which I used with VirtualDJ remote. Since the update in December only iOS 13 is supported rendering my 2 iPads useless (which were working perfectly fine I might add). Due to their age they'll only ever run iOS 9. Is there anyway to get the previous version? I don't mind doing whatever it takes to the iOS as they're only used for this 1 purpose.
Thanks.
Thanks.
geposted Mon 30 Mar 20 @ 1:44 pm
SOLVED
Just go in to the App store & click on the VirtualDJ Remote app. It will then ask if you want to download the last compatible version & that's it.
geposted Fri 03 Apr 20 @ 11:44 am
