Hi
I have Detune FX on PAD 1 in my (custom) PAD FX.
But how do I activate SLIP-mode for (only) the Detune FX, so when I push PAD 1 it will only activate SLIP-mode while the Detune FX is active?
(Detune active = SLIP ON, Detune not active = SLIP OFF)
This is push-action I already have on PAD 1 in the PADS EDITOR:
effect select 'detune' & effect_slider 1 0% & effect_slider 2 50% & effect_slider 3 85% & effect 'detune' active while_pressed
EDIT:
Found it :-)
effect select 'detune' & effect_slider 1 0% & effect_slider 2 50% & effect_slider 3 65% & effect 'detune' active while_pressed & slip while_pressed
EDIT:
Found it :-)
geposted Sun 05 Apr 20 @ 8:49 pm
add this on the end of your script
slip_mode on while_pressed
geposted Sun 05 Apr 20 @ 8:53 pm
Yes, thx Locodog!
I found it and edit my post while you were answering, i guess ;-)
geposted Sun 05 Apr 20 @ 9:06 pm
