What is the best way to remove the fader tabs from Pioneer gear? I have a DDJ-SR2 controller, that I want to put a skin on. When I did the same for my DDJ-SB2, the inside of the tabs broke and were never tight after that. So is there a safe way to remove, without damaging them?
geposted Fri 10 Apr 20 @ 10:58 pm
Maybe this video helps ;-)
geposted Fri 10 Apr 20 @ 11:55 pm
That's the shit, thank you, my brother. That makes life a lot easier.
geposted Sat 11 Apr 20 @ 12:07 am
