Hello
I have multiple playlists in Deezer and practically all of them show correctly in VDJ. Only of a couple playlists VDJ keeps saying that they are empty. They are most certainly not empty.
What could cause this?
I have logged out several times from Deezer and VDJ without succes...
thanks for your advice...
Dennis
Dennis
geposted Sun 12 Apr 20 @ 10:40 am
Post a screenshot of the playlist at Deezer, and same at VirtualDJ ?
To get a sense of why and what
geposted Sun 12 Apr 20 @ 10:56 am
printscreens :
![](/img/309311/65580/Knipsel1.png)
![](/img/309312/71483/Knipsel.png)
geposted Sun 12 Apr 20 @ 3:20 pm
Perhaps check privacy setting, as well as is it only the ones with colon in the playlist name that dont work?
And got a link to this playlist, can try add it my end
geposted Sun 12 Apr 20 @ 3:35 pm
hi, it isn't the colon in the playlist's name as I have a lot of other playlists with colon's which load just fine with.
Here is the link to the playlist:
https://www.deezer.com/playlist/6911885064?utm_source=deezer&utm_content=playlist-6911885064&utm_term=3280060804_1586708939&utm_medium=web
geposted Sun 12 Apr 20 @ 4:29 pm
Will try add here. Could be some "illegal" character somewhere else perhaps. I see its a lot of "creative" names in that playlist.
With DISCIPLΞS etc. But probably something else.
geposted Sun 12 Apr 20 @ 6:14 pm
Problem solved itself.
Songs appeared again without me changing anything.
Thanks anyway :-)
Thanks anyway :-)
geposted Mon 13 Apr 20 @ 8:25 am
I'm having trouble with certain songs not coming up in my deezer playlists on vdj. Seems to be only recent this has been happening. Do I need to reset playlists or something.
geposted Sun 21 Nov 21 @ 9:21 am
