I'm running VDJ 8.2 on a Window 10 box I'm using a Behringer UM2 for mic and headphones. I want to direct monitor the headphones. The Behringer has a switch for that.
My outputs are Master to VB-Cable (it's then going to BUTT for streaming), and the USB Audio Codec (the Behringer, for the headphones). The input is the USB Audio Codec (The Behringer with the Audio Technica mic connected).
What I'm unable to figure out how to do is prevent the mic from being included in the mix being sent back to the Behringer, so that I'm hearing only the decks and the directly-monitored mic in the headphones. The mic audio is sent back with a small, but distracting delay.
In other, inferior DJ software that I won't name, there is a switch that toggles sending the mic to the headphones, on and off. Is there a way to accomplish the same result in VDJ 8.2?
Thanks.
Thanks.
geposted Wed 15 Apr 20 @ 10:05 pm
it's an option, search options for "mic" it's there somewhere
geposted Wed 15 Apr 20 @ 10:08 pm
I'd have thought so. Everything there is:
http://stylesdeluxe.com/ss/HuaweiSS-2020-04-15-218.png
geposted Wed 15 Apr 20 @ 10:23 pm
Solved. I figured out how to delete the headphone output, add a booth output, and select "no" for boothMicrophone. Happy camper here.
geposted Thu 16 Apr 20 @ 12:08 am
