Hi, on my controler i have 2 buttons was doing the same thing on same variable:
set "$global_var" 1 while_pressed
it's working well, but if I press the 2 buttons simultaneously: The $global_var was set to 1 continuously when I release the buttons
to avoid it, I tried this but it's not working at all (the var is not changed)
up: set "$global_var" 0 : set "$global_var" 1
and i tried this but it does not change the behaviour:
set "$global_var" 1 while_pressed && up: set "$global_var" 0 : nothing
do you have any idea.
Thanks !!
Thanks !!
geposted Thu 16 Apr 20 @ 4:34 pm
Yes, whilepressed is "and repeat as long as key is pressed"
use "temporary" to "wait for key to release"
if var was initialy set to zero: push Button1 remember it was 0 set it to 1
while Button1 is down pressing Button2 : it remember it is 1 set to 1
press button 1, set to 1 remembered 0
press button 2, set to 1 remembered 1
release button 1, set back to remembered 0
release button 2, set back to remembered 1
up ? set "$global_var" 0 : set "$global_var" 1 whilepressed
press button 1, remember 0 set to 1
press button 2, remembe 1 set to 0
release button 1, up set to 0 set back to remembered 0
release button 2, up set to 0 set back to remembered 1
press button 1, set to 1 remembered nothing
press button 2, set to 1 remembered nothing
button 2 already down set to 1 again
up ? set "$global_var" 0 : set "$global_var" 1 temporary
press button 1, set to 1 remember 0
press button 2, set to 0 remember 1
release button 1, set to remembered 0, up set to 0
release button 2, set to remembered 1, up set to 0
the release order differ between whilepressed and temporary
geposted Thu 16 Apr 20 @ 6:11 pm
Thanks a lot for your clear explanation how works "while_pressed" and "temporary"
a lot of reply need to be on wiki :)
but on this script my issue is a test with ":" insted of "?"...
I don't know why I didn't see it...
Sorry for this simple syntax issue...
Thanks again for your help
geposted Thu 16 Apr 20 @ 7:20 pm
