I used VDJ 8 to do audio broadcasting and I am not able to anymore...I am getting this error message as follows: Ups! Failed to connect to your broadcast. Your broadcast is not reachable. Either your computer has not open port 8000 for incoming connections, or the broadcast connection has ended.
everything was checked out on my end and with my cable provider. Help please.
geposted Mon 20 Apr 20 @ 2:28 pm
You probably just have to open port 8000 in firewall and/or router
See here : https://www.virtualdj.com/wiki/open%20port%20for%20direct%20broadcast.html
geposted Mon 20 Apr 20 @ 2:30 pm
Thanks for your response, I have checked and double-check my port (8000) and its opened.
geposted Mon 20 Apr 20 @ 2:41 pm
I am still having the issue...Any help?
geposted Mon 20 Apr 20 @ 3:19 pm
How did you check that port 8000 was open?
geposted Mon 20 Apr 20 @ 4:13 pm
then your port is not open, see at the link at first comment
ok thanks will do.
geposted Tue 21 Apr 20 @ 3:51 pm
