When Iuse the beatgrid effect it works as expected, but when open the settings for the beatgrid it opens with a grey grid as shown in the picture. When I click on one of the squares, as long as i keep the cursor on it and keep the left mouse button pressed it turns purple. However when i release the mouse button it turns back to grey. I have tried to uninstall and reinstall but without succes. I would like to edit the grids but I can't. i hope i made it clear what the problem is. can someone help me out?
Thanks in advance.
Thanks in advance.
![](/img/310866/8256/beatgrid.png)
geposted Wed 29 Apr 20 @ 8:10 am
fixed with early access build 5680
geposted Wed 29 Apr 20 @ 9:40 am
Thanks, after the update it is working again however not quite right yet. In every slot, there are 4 squares divided up in 4 lines and 4 rows. In the first row of every square you can't switch it off, just move it up or down, why isn't it possible to switch this first one on or off?. In the other 3 rows of every square you can turn them on or off (grey or purple) also if you hover the mouse over one of the activated (purple) squares in the text showing it says that that particular block is off.
geposted Thu 30 Apr 20 @ 8:26 am
That's how it worked, since day 1
geposted Thu 30 Apr 20 @ 9:58 am
ok, but maybe an idea for a next version? just to expand the possibilities of this plugin?
geposted Thu 30 Apr 20 @ 11:43 am
VST plugin not working!
geposted Thu 30 Apr 20 @ 6:07 pm
