Hi guys, was just wondering how I would go about setting up my Behringer mixer as an "external" mixer while using VirtualDJ Pro and how I would then run my two Numark NDX900 through this mixer, so far I'm having no luck, I can get one output however my other CDJ won't play any audio through my connected speakers, I am using a laptop so with a little research it seems I may require an external soundcard?, can anybody with a little more knowledge explain how I could go about setting all this up? I have also tried to set up so each CDJ is its own soundcard however I am still not getting the split audio through my mixer.
Any help is appreciated thanks.
geposted Sun 03 May 20 @ 9:59 pm
You need to explain or show how you've got everything wired up, and your audio config in VDJ.
It seems to me that you should be able to use each NDX as a controller & audio output (to feed into the mixer).
geposted Mon 04 May 20 @ 5:05 pm
