Software: Virtual DJ 2020 (32 bit)
Controller: DDJ-200
I'm a bedroom DJ
can anyone help?
Controller: DDJ-200
I'm a bedroom DJ
can anyone help?
geposted Fri 08 May 20 @ 7:34 pm
If you load tracks using your controller, perhaps you have used the action... settings ... accidentally in your custom mapping ??
Does it also happen if you load the tracks with mouse ?
geposted Fri 08 May 20 @ 9:32 pm
yes thanks. somehow added settings to an action. thx for your help.
geposted Fri 08 May 20 @ 10:30 pm
