Topic: Button for Video Mode?
Hy.
How can I map a Button , to toggle from Video Only Visualisations to the Videomode where Transitions in the Video Pannel?
Greetings Dani
geposted Mon 18 May 20 @ 6:10 pm
Its automatic., as soon as you start mixing videos.
Or maybe you meant how can you "turn off" video mixing, to show the "simple sources" while you do video mix?
If so, just use overlays instead as video effects. For example deck master video_fx "Slideshow"
No , I mean change the View in the Video Pannel .
In one View there is on top AudioonlyVisuals slot , and under this the VideoFX slot...
And when I the Dropdown open by VideoSouce and click on (transitions) , the the Pannel Change to the other View where on the Right Side the Video FX Slot and on the Left Side the Video Transitions Slot.
And I will map a Button on my Controller to change this , toggle this ;-)
I have try this commands but dont work.
set 'video_source' `(transitions)`
toggle 'video_source' `(transitions)`
Ahhhhhh!!!
Have found the Command :-)
Must map this on a Button , then toggle :
has_video_mix
This is what I mean , there must more explain for many commands in the Mapper and Settings from the Program to the users ;-)
Nice Evening :-)
Thank You for the help
there is even this script too
lots of things have evolved
auto_crossfade
Understood what you meant, but not what for ;-)
Its automatic when you mix video files, and if you want to "go back to simple", its probably better to use the overlays (that are same as the simple sources)
But sure, if you prefer that view, can map it
Because I need this bevor I load any Overlays or video ;-)
Example:
I toggle to the Audio Only View , than I select the Audio Only Visual with a other encoder Knop on my Controller.
Or I toggle to the Video Transition Mode View , than I select the Transition whith an Encoder on my Controller.
And then I open the Video Output on my second Monitor with a Button first.
I need no Mouse then .
And I can see all in my skin View ;-)
ah .. ;-) understood..
I love to control all :-)
And I love Virtual DJ because its so flexible in many things.
