Topic: VDJ Keeps Crashing/Freezing in the middle of my sets
For some reason this has only been an issue for the past couple weeks. I will be mixing along just fine, there is a quick glitch in the audio, then connection with my controller drops, then VDJ freezes up completely and forces the task manager window to pop up and quit the program. Its quite frustrating to be in a groove livestreaming and have this happen every set at some random point. Any ideas whats causing it?
geposted Sat 06 Jun 20 @ 8:01 pm
Which controller?
Numark N4
Are you using PC or Mac?
Have you tried swapping out the USB cable? Are you using a direct USB connection between computer and controller (no hub)?
Which type of USB port are you connected to? Have you tried using another USB port?
