Am playing exclusively videos
I have a large playlist in Automix. The "Will play out" display is broken. Clicking on the header to sort does not work. See attached screencap.
![](/img/314226/45043/Automix.png)
geposted Fri 12 Jun 20 @ 2:22 pm
V8.4-64 b5872
geposted Fri 12 Jun 20 @ 2:33 pm
Looks like there was indeed a bug showing the date in 12-hour clock mode.
As for the sorting, the automix list is always sorted by play at time, unless shuffle is enabled, so I guess that was the case here.
If you want to see the order, you should use Shuffle Once instead of Shuffle mode.
geposted Fri 12 Jun 20 @ 4:22 pm
Ok let me double-check that shuffle setting again (As I'm still streaming with it)
geposted Fri 12 Jun 20 @ 4:32 pm
Looks like you were right regarding the shuffle. I used the Shuffle once but that's revealed another oddity - it looks like it shuffles about the first hundred or so tracks then leaves the remainder in alphabetical order ie un-shuffled. I needed to do the 'shuffle once' numerous times to get it to truly re-arrange the order of all the tracks. Not sure if this is due to the size of my list or something else
geposted Fri 12 Jun 20 @ 4:57 pm
Don't you think it would be useful to actually specify how many tracks are in the list?
geposted Fri 12 Jun 20 @ 5:01 pm
Going by the time in the screenshot with tracks at approx 3:30 it's 1354 files.
geposted Fri 12 Jun 20 @ 5:07 pm
kradcliffe wrote :
Going by the time in the screenshot with tracks at approx 3:30 it's 1345 files.
It's probably larger than that, in the region of 4K
geposted Fri 12 Jun 20 @ 5:08 pm
