so i mentioned it in another topic but figured id report the bug.
if you say had a folder
C:\!DJ MUSIC\!DJ MUSIC
and if you had alot of files in the subdirectory and i wanna move
C:\!DJ MUSIC\!DJ MUSIC to C:\
so the 2nd subdirectory is now in the orginal.. Windows always let you WRITE INTO or over write if need be.. but Virtual DJ doesnt let you.. you should be able to do exactly what windows can do.. shouldnt have just SKIP or cancel.. as its annoying as right now its a headache as you gotta move files in windows file exploer then VDJ and then end up with dead links
geposted Sun 14 Jun 20 @ 8:15 pm
