So this is a very new and frustrating issue. Just finished a folder for a gig I'm doing this Friday, went to scan the song in the folder and VDJ shuts down, every single time. Even tried individually scanning them and the same thing. This has never happened before and I did have a new VDJ update very recently. According to the system I'm currently using v8.4-64 b5873.
Any help would be appreciated as I have events coming up in the next few days. Yikes
geposted Tue 16 Jun 20 @ 10:33 pm
have you tried a different folder maybe one of the files is corrupted in the folder causing it to shut down
geposted Tue 16 Jun 20 @ 11:24 pm
It is all folders. I've tried scanning most of them. Same thing happens.
geposted Tue 16 Jun 20 @ 11:27 pm
I can confirm. It's the same on my MacBook Pro.
My Mac scans 3 files at a time, after the first 3 when it moves to the next 3 VDJ crashes. This is on b5873.
I tried several folders with the same effect.
I went back to b5872 and that one works fine.
System Specs;
MacBook Pro 15” 2017, 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3 Memory, Radeon Pro 560 4096 MB, Intel HD Graphics 630 n1536 MB, macOS Catalina 10.15.5, 500gb SSD, external WD Passport Ultra 2Tb HD containing Music & Video databases and is formatted NTFS, I use the Paragon plugin with NTFS for Mac.
VirtualDJ 2020 b5872 and Controllers - Denon MC7000, Denon MC6000 MkII (backup).
System Specs;
geposted Wed 17 Jun 20 @ 12:58 am
System Specs;
System Specs;
Is this a new result for you as well? I swear this didnt happen to me on yesterday 🤣😂🤣😂
geposted Wed 17 Jun 20 @ 1:38 am
Early Access build... 4 songs scanned and crashes every time. oh well... we'll wait for a fix.
geposted Wed 17 Jun 20 @ 4:23 am
Gotcha. So how do I revert back? LOLOLOL
geposted Wed 17 Jun 20 @ 5:17 am
geposted Wed 17 Jun 20 @ 8:07 am
Thanks, reverting works perfectly
geposted Wed 17 Jun 20 @ 8:41 am
I'm having the same problem on a Windows 10 laptop since the 5873 build this morning,
Scanning multiple files is much slower than usual and crashes after 3 files
Windows 10 Home 64 bit, running 64 bit version of VDJ
Intel i7 8th Gen
16Gb Ram
Intel i7 8th Gen
16Gb Ram
geposted Wed 17 Jun 20 @ 9:09 am
New EA 5874 available now which should fix the problem
geposted Wed 17 Jun 20 @ 4:51 pm
YUP! working now. thanks Adion. give the Dev's an extra cookie in their ration.
geposted Wed 17 Jun 20 @ 4:54 pm
