Topic: Mysterious VDJ 2021 b5920?
Just noticed on the website in the download page all the versions are build b5920.
Mine was b5918 and ticked to check for updates and early access, but, wouldn't update to b5920.
There is nothing in the changelog about b5920.
I've downloaded b5920, but, obviously have no idea what has changed. Can someone enlighten me?
geposted Fri 19 Jun 20 @ 2:50 am
There was a bug where it was forcing some settings on the update. I guess it was that.
geposted Fri 19 Jun 20 @ 5:55 am
yes, that's correct. b5920 fixes a bug that caused updating from 2020 to 2021 to potentially reset some settings.
Since that's the only difference, and if you're on 5918 you already updated from 2020 and this new build wouldn't change anything, we didn't push automatic update from 5918 to 5920 that would just waste your time and not change anything ;)
geposted Fri 19 Jun 20 @ 7:46 am
Thanks for that Stephane, that clears that up.
As mentioned I manually downloaded b5920 from the website, but, was curious. I was 'on the ball' yesterday with everything happening with 2021. After posting about the new 2021 on the Official Facebook page I think I broke the internet. :-)
geposted Fri 19 Jun 20 @ 9:57 am
