My Virtual DJ crashes every time i load a music video on the deck. It reboots time and again and then suddenly closes itself. However, the audio music loads and plays perfectly . Here is my laptop Specs and it is currently using Intel HD graphics 3000 and AMD Radeon HD 7400 Series
Operating System: Windows 10 Pro 64-bit (10.0, Build 19041) (19041.vb_release.191206-1406)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: HP ProBook 4730s
BIOS: Default System BIOS (type: BIOS)
Processor: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz (4 CPUs), ~2.3GHz
Memory: 4096MB RAM
Available OS Memory: 4030MB RAM
Page File: 4194MB used, 3164MB available
Memory: 4096MB RAM
geposted Tue 23 Jun 20 @ 7:15 am
Same here!!!!!!
Surface Book 2 fully loaded!
When installing the new stems version it asks to update video drivers! I have done this and VDJ the stops asking but when loading videos almost all the time it will crash or freeze VDJ!
I rolled back the video drivers thinking it was the cause and VDJ still has the issue.
An easy fix to operate is to turn off video skin and disable video output. Then I can play MP3 and MP4s just fine.
VDJ 2021 with video on will cause the PC to disconnect the external screen altogether and cause crashes both in VDJ and Windows 10.
Please address ASAP! I know for videos and couldn't play one last night!
John (AKA DJ Ricco)
John (AKA DJ Ricco)
geposted Sun 09 Aug 20 @ 4:34 pm
Please don't cross post. You already posted the exact same thing in another thread.
geposted Sun 09 Aug 20 @ 5:59 pm
I have the Same Problem. Please advice!
geposted Mon 12 Apr 21 @ 5:10 pm
Try using a desktop instead of a laptop with more memory on board as the memory cache may too small in laptop just a thought.
geposted Tue 13 Apr 21 @ 2:30 pm
same here and in a gig
geposted Fri 10 Jun 22 @ 10:27 pm
Looks like your crash is caused bt K_FPS64.dll, part of Razer Cortex so try to Uninstall that software
geposted Sat 11 Jun 22 @ 1:16 am
Imho you should have at least 16GB of RAM if you're working with video. 32GB would be better. I think VDJ is trying to load your Video and music files into RAM for playback. If you only have 4GB of RAM and you load a 2GB video file for example your entire system is only left with 2GB of RAM to work with. Or if you have two or more decks going you won't have enough RAM to cache the loaded files which will end up crashing the program to save the whole system from going down. Someone please correct me but I don't think VDJ and other DJ software plays back your files directly from your Hard Drive or SSD. It instead loads any files into RAM and plays them back from there. I could be wrong about that but I think that's how the software works so you have to have at least enough RAM to load any files that you want to play AND have enough Memory left to comfortably run the software AND the rest of your system. Playing music is no problem because mp3 file sizes are so small you could load up 10 decks with music and still have enough RAM left to spare. Video files are MUCH larger and require a lot more RAM to load into cache for playback.
geposted Sat 11 Jun 22 @ 7:27 am
No, the entire video file is not loaded into memory.
You do need a bit of extra memory and video memory to hold some buffer of uncompressed frames, but 8GB will most likely be enough.
geposted Sat 11 Jun 22 @ 9:23 am
