I am getting a considerably delay while loading new songs / even having them analyzed before. When streaming a video, i get an image or frame frozen for a moment and then suddenly starts working fine.
I knew by fact that now virtual analyzes the song and separate voice and instruments, but I would like to know if there is any setting to improve the loading timeframe?
geposted Wed 24 Jun 20 @ 5:21 pm
Setting, no. Better computer, yes.
The other option is to pre-analyse the files.
geposted Wed 24 Jun 20 @ 5:33 pm
Thanks a lot for the quick response, I did analyze the songs before the test and same result / having a new computer will be hard in these Covid days :) LOL -
I have a MSI core i 7 / with 8 gbs and running with SSD hard drive 1TB - Nvidia 920m GPU - as well pimped virtual memory and performance in the system - (just in case) - so I thing my computer meets an average computer settings required to run 2021 - if not please advise - it is very weird though... but happy to learn new things and looking forward using 2021 as I really love it !!
I just noticed my Nvidia drivers were old so I am currently updating drivers for Nvidia as well for intel GPU drivers /
When I opened 2021 for the first time I received a warning asking to update Nvidia drivers what I clearly dismissed / jejeje / now I am on it to see if that improves performance -
The main issue is only happening when streaming mostly - when playing normal / it kind of works somehow better / (FYI)
geposted Thu 25 Jun 20 @ 3:52 am
No, not "analyze for BPM etc". There's a new option called "Precompute stems".
geposted Thu 25 Jun 20 @ 8:47 am
And if you don't want to use the new feature at all, you can set the option "mathEngine" to disabeld. And loading will be as instant as before.
geposted Thu 25 Jun 20 @ 9:10 am
Drivers updated and still same behavior so far!
geposted Thu 25 Jun 20 @ 11:59 am
I really want to use the new feature :)
geposted Thu 25 Jun 20 @ 12:01 pm
That's what I did for some folders, I will do that for the rest and then test!!!!
geposted Thu 25 Jun 20 @ 12:02 pm
really appreciate the help!
geposted Thu 25 Jun 20 @ 12:03 pm
Ahh this is great / will look for this and will test!!! =)
geposted Thu 25 Jun 20 @ 12:06 pm
Just make sure you have plenty of free space on your hard drive...
geposted Thu 25 Jun 20 @ 12:07 pm
Thanks boss! jeje / I have 300 GBS free in my 1st partition!!! I think that makes the trick! will try!
geposted Thu 25 Jun 20 @ 12:19 pm
BUENAS NOCHES, TENGO UN PROBLEMA CON VIRTUALDJ 2121, ESPERO Y ME PUEDAN APOYAR, YA QUE AL CARGAR UNA VÍDEO LA PANTALLA DE VÍDEO SE TORNA UNA CORTINA VERDE QUE HACE COMO STROGO, Y AL CARGAR VÍDEO EN EL OTRO PLATO AL MEZCLAR SE BLOQUEA Y SE APAGA EL VIRTUALDJ Y ME SACA Y SE VUELVE A REINICIAR COMO DESDE EL PRINCIPIO, ESPERO Y ME PUEDAN APOYAR...
geposted Fri 26 Jun 20 @ 2:21 am
Por favor pregunte nuevamente en inglés o use el foro en español.
https://virtualdj.com/forums/12/Spanish_Forum.html
geposted Fri 26 Jun 20 @ 5:49 am
