hi guys,
i know back in the days
amd graphic cards weren't recommended for virtual dj
i guess it hasn't changed much
anyways...
i just replaced my old laptop with a new one
i only use it for djing with virtual dj
lenovo thinkpad 13s
i5
win 10 64bit
intel uhd graphics 620
radeon 540x
first time using a radeon
i spent a few days trying to get it work
(google, youtube, various forums...)
failed
how can i get virtual dj to recognize radeon 540x?
thanks in advance for any input,
matt
anyways...
lenovo thinkpad 13s
i5
win 10 64bit
radeon 540x
failed
matt
geposted Thu 09 Jul 20 @ 10:10 am
recognized in what way?
For video mixing? will work and do the job ..
But I guess you mean the new stems feature? its only on Nvidia for now, for Windows (and AMD for now on Mac).
Will still work if you dont have, just using the CPU instead.
https://www.virtualdj.com/wiki/Minimum-system-requirements.html
geposted Thu 09 Jul 20 @ 10:21 am
i meant, if i right click on the master video output
only the intel video card would show up
even in the option menu
loading was super slow
playing was choppy
for some reason out of nowhere...
(or maybe i just don't remember... because i tried so many things...)
although the master video output says intel
in the option menu it says radeon
and everything works flawless
even stem works
haha
awesome
thank you so much for the input
geposted Fri 10 Jul 20 @ 8:44 am
Try this, right-click the start icon on your desktop for VirtualDJ, and choose "run graphic processor with Radeon"..
Not sure AMD has this, but common for Nvidia. With AMD, I think you need to use the AMD Catalyst Control Center instead, and do same there
geposted Fri 10 Jul 20 @ 9:59 am
On AMD i think you add in the Radeon settings
https://www.amd.com/es/support/kb/faq/dh-017
geposted Fri 10 Jul 20 @ 10:02 am
