What is the trick to making the displayed singer list a larger font?
Love your software!
Love your software!
geposted Thu 09 Jul 20 @ 1:58 pm
Just click the option radio dot at top right corner in the Karaoke sideview.
Under "Singer List Display.." click "edit this skin" at bottom.
Then you'll see an xml file you can open in any text editor with a short xml code, where its often very easy to see what is what..
Just look for the action= get_next_karaoke_song 'singer' and set text size="XX" to a larger size :) Thats it ;-)
(when edit is done, it will show up in same "Singer List Display" list as mentioned above, and yours will be with (Edit) on end)
geposted Thu 09 Jul 20 @ 2:35 pm
