"Since the recent update that reordered the setup page and renamed the controllers section to "mappings", I no longer see the option to check independent pad page per controller. Now all my midi devices switch pages when any one of them does. Help?
geposted Sun 19 Jul 20 @ 3:56 pm
http://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/pads.html
Check out the section around controller assignment.
Each controller can have its on page applied to its controls. So controllers can be independent, but setting it up is slightly different.
One you get used to it, it’s actually much easier to change and tweak to your personal preference.
geposted Sun 19 Jul 20 @ 4:37 pm
Thanks Dan. I must have encountered a bug somewhere in the process. The manual says that all midi controllers should appear in the pads menu, but all I get is "Page 0" (see SS)
![](/img/317337/37863/vdj.png)
geposted Sun 19 Jul 20 @ 6:02 pm
What controller is it?
geposted Sun 19 Jul 20 @ 6:13 pm
You may have to trigger a page change on the controller for it to show.
geposted Sun 19 Jul 20 @ 7:25 pm
Initially I saw the error with my Rane Twelves, Traktor F!, and DDJ-XP1 attached. But I have tried every controller I own ddj-sb2/and sb3 ddj1000, reloop neon, etc.
I did try to trigger pad changes from all the different controllers and still get no controller showing in the pads list
geposted Sun 19 Jul 20 @ 8:19 pm
If I launch my 32 bit version(which has not taken the "easy" pad page update,) everything works fine.
geposted Sun 19 Jul 20 @ 8:25 pm
The new pad page assignment works with default mappings, custom mappings created after the update or custom mappings using the pad_page # instead of pad_page name for the pad mode buttons and their leds
geposted Mon 20 Jul 20 @ 3:44 am
Thank you Dad. Got it fixed. It was the page calls in my mappings.
edit
Well I thought that fixed it... But still not seeing controller names in the pads menu
geposted Mon 20 Jul 20 @ 6:31 am
Of course you have to use default skin (or an updated custom skin) to get the full size menu...
Older (not updated) skins will allow you to change only "current" pad page
geposted Mon 20 Jul 20 @ 12:42 pm
So what's the change in code that breaks all existing skins? Is it in the wiki yet?
geposted Mon 20 Jul 20 @ 1:27 pm
This is still broken, and I can't find any way to get the custom pads that I use at every gig to work on my devices the way they did pre-update. The change to the pad system should be rolled back or optional.
geposted Wed 22 Jul 20 @ 4:03 am
Which bit isn’t working?
I also struggled when using this change. But once you get used to it, it’s much easier to assign and change pad pages.
geposted Wed 22 Jul 20 @ 11:40 am
It is even the default now that if you have 2 controllers that each controller can select their own pad page (which is why the original option for independent pad pages isn't needed anymore)
So what is exactly not working anymore?
geposted Wed 22 Jul 20 @ 11:54 am
when I select a pad page on one of my controllers, all of my other controllers switch to that pad. Pre-update I was able to have my Traktor F1 on a custom pad I have for weddings, my ddj-xp1 on hotcues, or another custom pad, and my ddj-sb2 on loops or samples. Now they are all stuck to the same pad.
geposted Wed 22 Jul 20 @ 12:17 pm
That should still work. What action is assigned to change the pad on the controller?
geposted Wed 22 Jul 20 @ 12:21 pm
This is mapped to PAD_MODE_SAMPLER on the DDJ-XP1;
pad_page 'sampler' ? pad_page 'keycue' : pad_page 'sampler'
This is mapped to STOP1 on the Traktor F1(I use the stop keys to switch decks and as a quick pad swap)
doubleclick 200ms ? pad_page 'rane twelve left' : deck 3 select
geposted Wed 22 Jul 20 @ 12:42 pm
Is there a way I can revert back to the previous build? I have gigs on Friday and Saturday, one of which is a wedding(where I need my custom pads and mappings the most)
geposted Thu 23 Jul 20 @ 12:17 am
Support/wiki/download previous builds
geposted Thu 23 Jul 20 @ 8:14 am
Thank you Groove.
geposted Thu 23 Jul 20 @ 12:12 pm
