Hi I am have some issues with the new software 2021 and that is keeps on disconnecting while I am broadcast my internet radio. My broadband is Sky and it is very fast. How do I keep it connected longer and not disconnecting, thank you.
From Jeremy Knight
From Jeremy Knight
geposted Fri 07 Aug 20 @ 9:47 am
Define disconnecting.
You’re getting an error message inside VDJ?
Listeners lose stream?
Something else?
Most issues are usually caused by a poor internet upload connection. Drop in WIFI if your using that. Or an issue at the server.
Where are you broadcasting to?
Something else?
geposted Fri 07 Aug 20 @ 11:00 am
